Why are you so concerned about the brakes? Is there a vibration when you stop? New pads and even new rotors won’t improve braking performance significantly. You don’t need new brakes for thousands of miles and perhaps several more years. Rotors can be measured, and if they are within specs leave them alone until and unless you have a braking problem.
Fix the shocks. If you must spend money take a look at your tires. Winter tires will do more for you stopping in bad winter weather than new brake pads and rotors.
