What are your thoughts on EV Charging Entitlement Syndrome?
How? Don’t residences typically have 240V service only?
240V 200 Amp is the highest the standard single phase residential service drop will support. If there is 3 phase at the street, then they can bring 3 phase to your house if you want it I believe. If you need more than 200 Amps you can have a higher service installed. You can make any Voltage you need with a transformer. They can bring the medium Voltage supply to your own transformer on your property if you like. You’ll see these transformers by businesses around back by the dumpsters. Having all this installed won’t be cheap though.
