I have a 2013 Mustang GT with the 5.0 engine and 6r80 automatic transmission.
Lately starting a few weeks ago, I have been having a shift flare when shifting from 2nd to 3rd and 3rd to 4th gear. Interestingly, 1st to 2nd gear shifts normal every single time.
When the shift flare happens, rpms will rise by a few hundred before shifting into the next. The shift itself is not rough. It doesn’t exactly feel like a slip. I uploaded a video and if you listen and watch the tachometer you will see what I mean especially if you observe what 2nd to 3rd and 3rd to 4th shifts look and sound like compared to my 1st to 2nd shift. Again, it’s not exactly a slip but it just doesn’t seem normal especially compared to how 1st and 2nd shifts.
Some other important things to note:
-I have no delayed or rough engagement when shifting from park to reverse, reverse to drive, drive to reverse or park to drive. Instant smooth, engagement and NEVER delayed, rough or clunky.
-Besides the shift flares there are no other drivability issues. No transmission codes (scanned with forscan), cruising is smooth, trans never drops gears or slips badly.
-Car can drive for hours no problem, in highway or stop and go, no other problems besides flare and flare does NOT get worse as car warms up
-Have a device that monitors transmission temps and even after very long drives, the trans never gets hotter than 190 degrees and is usually 185 degrees or lower. If I do multiple hard wide open throttle pulls the temps rise to maybe 195-196 but after the oulls the temps quickly cool back down to 185~.
-No weird noises EXCEPT for a metallic whistling noise that is only audible in reverse OR drive when car is idle. In park and neutral at idle, the noise is absent. Not sure if the noise is related to the flares but just something worth noting.
-I have cleared adaptive transmission tables using forscan as of today (November 17th) and flares persist
-No current or pending transmission codes as of today November 17th scanned with forscan
This issue has been difficult to diagnose or at least decide where to start because there were many conditions that changed simultaneously when I first observed the 2nd to 3rd and 3rd to 4th shift flares.
The timeline is something like this:
August 1st 2026 - car ran, drive and shifted through all gears perfect. I got a custom ECU tune from Wengerd Peformance. If you do some quick research you’ll see they are extremely respected and established in the Mustang tuning world. After the tune, the car still ran, drove and shifted fine. The only major change was 1st to 2nd gear didn’t shift until 3k rpm instead of 2k rpm from stock tune, but he confirmed this is normal and intentional. None of the gears had the flare after the tune. Drove on the tune for 2 months, no problem.
October 1st 2026 - my lead frame in the transmission went out. I had all the classic symptoms. Multiple p07xx codes, all dash lights turned on, speedometer stopped working, loss of select shift when put into sport mode, and the transmission randomly downshifted without warning into 1st gear when going highway speed (luckily no one was nearby and I was able to safely pull over and get towed) and then after the random downshift event, my car was stuck in limp mode and locked in 3rd gear.
October 15th - car sat for a couple weeks. On this day, I replaced my lead frame along with brand new OEM Mercon LV fluid, OEM Motorcraft gasket and filter (FT 188) and OEM Motorcraft lead frame. I am 100% sure I did the work correctly, I retorqued all valve body bolts to spec, all connectors seated properly and I observed the old trans filter had the orange o ring on it when it came out. I also had the battery disconnected for all the work and cleared all codes before turning on for the first time after the repair. And yes I double and triple checked my fluid level and verified it’s correct at 180 degrees.
This is where things get fuzzy. I was so glad I had fixed the lead frame issue and car was driving so well, it is hard to say if the flares immediately began after the transmission work.
Around this same time, I requested a tune revision from my tuner to lower the 1-2 gear shifts from 3000 to 2000 rpm because this was getting annoying in stop and go traffic. I loaded the revision on my car and now it shifted 1-2 at 2000 like I requested but now I noticed a flare from 2nd to 3rd and 3rd to 4th. It’s hard to remember if it was there before the tune but all I know is the mechanical work and tune both changed at the same time.
What makes me less inclined to believe it’s the tune is this
-On October 20th maybe, I reloaded the original tune from August 1st that drove with no shift flares but now the shift flares were present.
This makes me suspect the new hardware (ie the new lead frame and transmission filter since those were the only other things that changed since the shift flares started. HOWEVER, I have zero of the symptoms symptoms of a bad lead frame like I did before when it was previously failing.
So the only other hardware suspect is the filter. This is the confusing part for me. If the filter were severely out of position or had fallen down, the car would likely not move forward or there would almost certainly be a delay when going from park to reverse, reverse to drive, etc and changing gears on the gear shifter is perfect perfectly smooth with zero delay. However, from what I’ve read 1st to 2nd gear being smooth while 2nd to 3rd and 3rd to 4th flaring aligns with a pressure issue, which can probably be traced back to the filter since that’s the only hardware that changed.
What’s more is that from my understanding due to the geometry of the transmission pan, it will physically not bolt back up to the transmission if the filter isn’t aligned into the valve body properly. So the fact that my pan was able to back up, makes a misaligned or fall off filter virtually impossible because once the pan is up, it presses against the filter and physically hold it there.
The only other possibility is that maybe the O-ring on the new filter got damaged and I didn’t notice it, so while it may be aligned properly, there might be a tiny gap or tear in the O-ring on the new filter which could be causing a very small air leak or causing the transmission to suck a tiny bit of air in, explaining why I’m getting shift flares but not delayed engagement or pump whine, since the leak isn’t severe enough.
Realistically, though the O ring on the new transmission filter being damaged seems very low since Motorcraft parts generally have very good quality control
This is all just speculation and I’m hoping somebody can weigh in.
If you made it this far, thank you so much for reading it all.
Videos below:
Shift flares: https://youtube.com/shorts/MY7z9yG4YhI?is=S2e9OGeLgVBsF1gO
Idle noise that only appears in reverse and drive and not park and neutral: https://youtube.com/shorts/msa6voLP_5g?is=TNJSw8V-EuFrClYc
