Still tells me nothing and while there are several variables including the cooler part of the year, roughly the high side should be around 225ish and the low around 35ish. The rough evaporator temp should be somewhat close to the low pressure reading; say 35 degrees.
Readings will fluctuate a bit as the compressor cycles on and off.
