Tried two different keys - but key will only turn to position 1, but not 2 (drive) or 3 (start position)
Make sure the shifter’s all the way in Park, wiggle it a little. Also try turning the steering wheel a little back and forth while you try turning the key.
this came up a week or so ago, check the brake switch and wiring.
