Valve guides - any real difference between intake and exhaust?
Yep!
The bore for the exhaust valve guides is different for the intake valve guides.
They’re different because the exhaust valve guides and valve stems are exposed to extreme heat, so they must expand at the proper rate together. Where with intake valves and guides, these see ambient temperature, so thermal expansion isn’t as much of concern.
