I was wonder if someone could explain how one might jump another dead car using a Ford Transit van as the live vehicle? The battery is under the driver’s seat and while they have put a positive terminal under the hood they only have a ground post under the hood and not and actual negative terminal. Since one would normally connect one of the cables to the negative terminal of the good battery and ground it on the dead vehicle i’m not sure where to connect the negative/ground cable on each vehicle. The dealer told me to connect it to the negative ground post on the live Transit and also a ground on the dead vehicle. Is this correct? Ground to ground? Of course the two positives are connected with the other cable but this is the easy part.
Thanks for any advice.
