I have a 2003 Ford Ranger that only starts when it’s cold. If I drive it for a bit so that it warms up, stop the engine, and then try to start it again, it will just continue to turn over. Once it cools down, it’ll start again. To make matters worse, now that the weather is getting warmer, it may or may not start depending on the time of day. Yesterday afternoon, about 70 degrees, no dice. This morning at about 50 degrees, started right up. When it won’t start, it’s as if it’s getting no fuel. The battery seems fine, and it’s trying and trying to turn over, but no.
Related topics
| 2003 Forester won't start (a second time) in the cold | 1 | 434 | February 8, 2014 | |
| Cold weather + hot engine starting problems | 4 | 1125 | January 14, 2017 | |
| Cold Starts problems? | 7 | 2298 | May 10, 2017 | |
| 1998 Ranger with trouble starting in cold weather | 0 | 599 | May 3, 2010 | |
| Won't Start When Cold? | 0 | 394 | April 7, 2010 |
