Thanks again, everyone. I’m going investigate the MAP ground issue and take a look at the threads on the #1 cylinder hole as GeorgeSanJose suggested. If the threads are good enough for a seal, I’ll do a leakdown test. If they’re not, I’m thinking of chasing them with a tap first. Thoughts?
Re: Yosemite and Nevada_545, I didn’t use the starter to rotate the engine, just a wrench. But I did have to rotate the cam and crank independently due to some mistakes I made, and several times I felt piston/valve contact and had to back off and and try again. Maybe I bent a valve.
Re: pleasedodgevan2, I think spark plug wires were a definite possibility, but I think they’re eliminated at this point.
I also replaced the head gasket when I put the head back on, so maybe I screwed that up. Hopefully a leakdown test will tell.
I’ll let you all know how it goes. Thanks again to everyone for your help
