1996 / 2.2 L4 / 186k / Upper engine rebuild 30k ago
Car was driven on a errand by my mother. Upon trying to leave for home, the car started running very rough, and stalling. From the description she gave on the phone, it sounded like a plugged up exhaust. I told her to get some fresh gas and ease it home after.
When I checked the car for codes, I got 2. A P0300 and a P0122. Okay, so the throttle position switch has taken a dump, that’s easy enough. The car has 186k miles, but my constant nannying usually soothes her, so surely that’s all, right? God, I wish that turned out to be true.
I pulled the plugs, and #4 was gas fouled and sooty, #2 and #3 looked lean, and #1 was partially wet fouled. There was also gasoline in the oil. When the car would run, it would run the gambit from idling semi rough then stalling out and refusing to restart, almost like it was flooded, to idling scarily bad and no pedal response, to running too high of an idle and idle searching.
Since I have:
Replaced the TPS
Replaced the IAC
Replaced the CTS
Replaced the MAP
Replaced the ICM
Replaced the FPR
Replaced both ignition coils
Replaced plugs and wires
Replaced the fuel injectors (thanks to those that helped me)
Replaced the PCV (I was desperate)
Replaced the fuel filter
Checked the pintle on the EGR (looked good, cleaned)
Checked for Vacuum leaks (as best I could)
Checked the Fuel pressure (40 PSI) (drops to 20 after shutoff)
Checked for exhaust restriction (ran open exhaust manifold)
That brings us to today. New injectors just in, and the engine will run, but rough and loud. It almost sounds like the firing order is off slightly (Im using 1342 or from L to R 4132) and throttle control is almost non existant. It also shuts off when its warm almost like its flooded. No codes are showing. (despite discovering a sensor in back being unplugged and the O2 sensor being unplugged at times)
I’m close to summoning the devil to make a pact.
