Thankyou for helping me out so much in the past. Now my work 2005 Grand Caravan check engine light is on and a auto parts shop has read the code as a problem with the transaxle solinoid switch. Is this a major problem?
Thank you.
Dan
seeing that you didn’t tell us which one of the 37 codes that apply to the “Transaxle Solenoid Switch”
How can we answer the question?
A simple web search shows that the Transaxle switch could be a problem if not replaced.
Short answer yes…
As mentioned, give us the code(s) and we can help you further…
