I noticed that under the front on my car on the passenger side I am finding small amounts of Trani. fluid. Under the hood it looks like there is something spread on the on the radiator on the bottom on. But my fluid level hasn’t seemed to go down in the past week since I have noticed this, I am checking it every day. In addition there is a “door creaking” sound that is almost unnoticable unless you really listen for it when I put the car into gear. Do I need major trani. work done?
Ir the transmission is operating normally then I would just make sure to find the leak, address it, and keep on going. Sounds like it might just be one of the cooler lines if you have a bit of fluid near the radiator. A little leak and a little ambiguous noise doesn’t mean much.
