willl it hurt to shift from second gear instead of first. it is a 4 speed w/overdrive in a f-150 ford truck. is there a pedal adjustment with the hyd clutch as mine doesn’t engage til real high in the travel?
Well if your load is light and first gear is very low and second is low, it might not hurt. However in most situations skipping first gear is hard on the clutch and engine.
Sorry, I have no idea if there is any way of adjusting the clutch. Have you driving another like truck, does it do the same thing?
