1996 4Runner V6 4WD with automatic transmission & 136K miles. I believe it has a limited slip rear end. Problem only occurs in drive, not in reverse. Put in drive & put on the gas & sometimes engine increases RPMs (1000) & it feels like it is trying to move but won’t (as if the brake were on). Then a “clunk” is heard & felt in rear & car drives normally. Only occur when starting from a stop. A few times on snow or ice one rear tire will spin & the other feels like it is dragging (not rotating). Passenger rear wheel bearing replaced about 1 year ago. Transmission fluid is fine & changed about 1 year ago. Thank you for your help.
Related topics
| Car won't move & clunk in rear | 7 | 6068 | January 1, 2011 | |
| 1999 Toyota 4Runner - Transmission (?) | 0 | 333 | June 16, 2010 | |
| Slipping tranny or rear end ? 2005 F-150 4X4 Lariat Crew Cab | 2 | 552 | June 7, 2007 | |
| Transmission or rear end | 2 | 668 | February 15, 2010 | |
| Rear end vibration | 4 | 481 | September 7, 2008 |
