My 1993 toyota pickup is having trouble going uphill and the engine temp rises then. Any suggestions?
Restricted radiator, worn water pump, low coolant, defective transmission, bad transmission fluid, restricted coolant circulation, radiator cap, or thermostate timing problem bad plugs/wires …
