My headlights and dash illumination lights will intermittently flicker when I use the turn indicator to signal a right hand turn. Is it possible that there is a short in the turn indicator/high-low beam headlight control switch that is causing this?
I think you are most likely correct about the trouble being within the switch itself but it isn’t a short that is causing the trouble, it is due to an interruption of power to the lights.
Thanks for the replies. If there were a bad chassis ground would it be logical to think the flicker should happen even without me using the turn indicator switch?
