What are the mfg recommendations for compression on a 1978 FJ40 (original 2F motor)? Book says new=150PSI. What is the minimum I should expect.
Compare the highest compression reading to the lowest compression reading from all the cylinders. If they’re all within 10% of each other, that’s good. If any are more than 10% of the highest reading, that’s not so good.
