My Toyota Corolla 2000, 123,000 miles, Mass license plate, still getting 34 miles per gallon, has had check engine light on and off for a year.
Failed inspection this June.
First garage in Somerville, without doing more than getting the three readings above, said catalytic converter was needed $350 plus labor.
I was unable to do the work then and returned to NYC and job. Took to another mechanic recently to get fixed (as I wasn’t returning to Mass for a while)
and got only PO 171. I mentioned the other readings; they kind of scoffed it off.
Trying to save me money (I guess), they cleaned the MAF filter and fuel ejectors for $200.
Looked like it was fixed. A week later check engine light came on again and when I brought in found the PO 420 reading.
They did not tell me if other computer read-outs were coming up as well.
Now they want to leave the oxygen sensor in front but change the one behind. Put in a new
catalytic converter $539 {they had quoted me $238 but it wasn’t an OEM one I guess and they said they wouldn’t warrenty anything but this expensive one), charge me
$137 for the oxygen sensor
190 labor
plus tax
for a total of a whooping $946!
I would do this but reading on web that the mechanic should have diagnosed the catalyst efficiency with a pyrometer and verified with a gas analyzer. I don’t know if he did (certainly not at the first garage) and am worried that i am going to pay close to $1000 [after paying over $700 a week before: $200 MAF filter clean; $250 tune up and parts!; $230 ac checked and re-filled but leak not found plus tax].
I am afraid they will do this very expensive job and the check engine light will come on and htey will say o its something else.
how can i be sure? also I was reading for a catalytic converter to go bad, something has caused it…what would that be? how to find out. Do they need to do the diagnosis with gas analyzer etc?
Please help before i spend a huge amount for an old car that is running well, not losing gas mileage, but perhaps is a bit slower on power [ a sign i read that could be the cat].
Help! I am trusting a very expensive garage and wonder if i should.
thank you if you can help asap.
best
Antoinette
