Toyota Avalon 2001 - Transmission fluid changes
A pan drop only allows between 25-35% of the total amount of transmission fluid to removed from the transmission.
The rest is held in the torque converter, valve body, and transmission fluid cooler and lines.
The only way to replace all the fluid is to perform a transmission fluid flush.
