My Toyota's AC will be ice cold when you first crank the car up for the day and most of the time the air will stay cold until you cut off car. When you crank the car back up and turn on the ac again it will blow hot air ( once in a while it will blow cold when AC is cut on the 2nd time but not often ) I check the temperature of the AC and it runs around 35° to 37°. I have had it vacuum out and new Freon put in. Did not change anything. I did notice the gauges when the man had them on my car's AC. The low side show 0 the high side read around 2 or 3 hundred. One man wanted to put a new compressor and dryer on my car , but when I ask if this would fix it he didn't think it would. I live on fixed income and I can not afford to keep taken my car to AC expert to look at it and not fixing it. No one don't know what is wrong with it. Can you help me please?
miles 169 thousand
