I have 1993 Ford Ranger 2WD. At 125,000 miles I changed the timing belt and water pump. When do I need to change it again. I am at 185,000 right now. Is it time to do it again?
Thanks!
I think I would go for it at 200,000 miles and you should be good until about 300,000. The best answer will be in the owner’s manual. How often does it say it should be changed?
