Hey folks! I have a noise coming from the interior of my car that is incredibly, amazingly, terribly obnoxious. Not to mention somewhat embarrassing when I have a passenger, and it decides to show off.
Part of the problem is that it’s unpredictable when it will occur. It could go weeks or even months without making the noise. Out of nowhere, it will start up again and continue once or twice day, or even any time I start the engine.
The best way I can describe it is: TUK-TUK-TUK-TUK-TUK-TUK-TUK-TUK-TUK-TUK-TUK-TUK-TUK-TUK-TUK-TUK-TUK-TUK-TUK-TUK
A brief pause of maybe 5 seconds…Then: TUK-TUK-TUK-TUK-TUK-TUK-TUK-TUK-TUK-TUK-TUK-TUK-TUK-TUK-TUK-TUK-TUK-TUK-TUK-TUK
If I switch the blowing knob from the driver setting to, say, feet, or dash, it’ll stop for a moment and then resume with the TUK-TUK-TUK-TUK-TUK
After it gets as many TUK-TUK-TUK-TUK-TUKs out of its system as possible, everything goes back to normal. During this process and afterwards, it blows cool/hot air at the correct setting, so no performance issues.
If you’re a musician looking for a car that will help you keep beat, I have the solution for you were with a metronome built right in!
Car in question is a 2006 Monte Carlo - Any possibility this is a relatively simple DIY repair? I’m comfortable with basic tasks like replacing car stereos, speakers, headlights, oil change…If this’ll require much more skill than those sorts of tasks, I’ll likely need to put this repair in the hands of a professional.
Appreciate any insight you all might have on this!
