Anyone tried this: Thermagasket ?
http://www…r-kits.htm
Claims that:
Q: What types of problems will Thermagasket repair?
A: Thermagasket will repair the following problems:
* Failing or completely failed head gaskets
* Warped heads
* Cracked engine blocks and heads
* Coolant leaks to the exterior of the engine through a breach between the head and block
* Coolant leaks through the head bolts
* Intake manifold coolant leaks
* Overheating due to a cracked head or block
* Oil leaks into the cooling system (Radiator)
* Coolant leaks into the oil
* Excessive steam and water from the tailpipe
While I was actively working in the garage customers never asked if we would try these products (sometimes they asked for JB-weld work, not really related) Perhaps if I saw more GM heavy line I would have been exposed to people wanting you to try these things out, I was never asked by a BMW customer to try these things. I wonder what are the details on the target car/owner for this product.
A one pint bottle of sodium silicate from a local pharmacy for about $20.00 will do the same thing as this stuff does.
Yes, but I suspect that dogboy1995 may be a spammer - so I don’t really thing s/he cares - or would want anyone to know that.
Yup!
Sure looks like spam to me.
