I’m having a heck of a time bleeding the brakes on a 1988 Ford Festiva. I replaced the master cylinder and bench bled it, replaced the front pads and in the rear I replaced the shoes, hardware, drums, and wheel cylinders. I pressure bled the brake system with a Motive pressure bleeder. On the test drive, it felt as if the rear brakes were not working at all. I manually bled the rears and I kept getting air out of the bleeders. No matter how much I bled the wheels, I kept getting air bubbles. It almost seemed as if both wheel cylinders were sucking air in, but not leaking fluid out. Is it possible that I have 2 defective wheel cylinders? Any idea as to what is going on here? Help!
Related topics
| Frustrating Festiva Brake Problem | 4 | 2337 | November 22, 2009 | |
| Can a master cylinder just fail during brake bleeding? | 13 | 35660 | November 17, 2007 | |
| Brake Bleeding Problems | 13 | 18107 | February 14, 2010 | |
| Brakes Bled but still soft pedal - 2002 Ford Taurus | 12 | 21612 | January 2, 2014 | |
| Brake Pedal Fading | 2 | 705 | October 18, 2010 |
