The question was about a temperature sign where a driver noticed the digits were exactly reversed, comparing deg C vs deg F.   28/82 & 16/61 (C/F) were the two answers.
But those numbers are actually rounded to the nearest integer.  28 C = 82.4, and 16 C = 60.8.
Here’s an extended version of this puzzler:  Are there any combinations in integer pairs that are exact matches?  So only pairs that are exact integers are allowed,.  0 and 32 are an exact integer pair, as well as 100 and 212.  There’s many others.   From that list, are there any where the pair match up when reversed?  I don’t think there are any solutions for positive 2 digit integers.  Do you agree?   If so,  what about negative 2 digit integers? I don’t think there are any of those that work either.    So what about 3  digit integer pairs?  Any exact integer solutions this puzzler?  If so , what’s the one w/the fewest digits.?  Or is there even one at all?
I don’t know, just asking.
              I started running an excel table to two decimal places with the formulas. But looking for the reverse matches made me crazy, so I gave up. My eyes got all buzzy and my brain almost exploded.
              I think there’s a way using Diophantine equations to find them, but the problem is I don’t know how to use Diophantine equations … lol …   maybe I’ll check a book out of the library and take a crack at it , thanks for giving it a go yourself TMB!
              I’m absolutely certain there’s a recognition program that’ll do this.
Unfortunately, I don’t have it!
              I used excel to check the first 10000 numbers with no matches (0 to 9999ºF)
edit, I can email the spreadsheet to anyone interested, or post it online.
edit2. also checked negative, to -9999ºF, no matches
              Bill, were you looking for reverse matches?
Direct matches could easily be done by adding a third column subtracting the first column from the second column. All the zeros are matches.
Finding reverse matches is a bit more difficult. I’m stumped for a formula. Anybody?
              I loked for reverse matches.  I used excel commands LEFT, RIGHT and MID to break the F number down to individual digits, then recombined them in reverse order via the CONCANTENATE command. Then compared the reversed F value to the C value via the IF command.
Only needed to check every 9 F values for obvious reasons.
you can download the spreadsheet at wfrjr.com/data/digits2.xls
EDIT: found an error, had to use the VALUE command to convert the reversed number, which is in text format, to an actual number. Still no matches.
              A tip of the hat to your ingenuity, Bill  !
