You beat me to that one. Busy today, was going to post exactly that comment. My first thought was he ran 6 Baja 500’s in that 3,000 miles. Or, 3,000 miles in mud on his way to the national mud championships. but, then I noticed he said conventional oil would have worked fine, which is preposterous.
Hercules Poirot, fictional detective, would ask, “Why did he put in synthetic at that time?” The answer is either he bought a sludged used car, or neglected it, and when he realized he had messed it up, decided to use the magic elixir, and when it didn’t instantly solve the result of his neglect, decided Mobil-1 was no good.
As someone just posted, those who pooh-pooh synthetics nearly always admit they have never used the stuff. Hee, hee.
In October I had my Mobil-1 EP tested after 8800 miles. Still good, and had enough additives left to run maybe 10,000 miles total. I notice the same pooh-pooheers also pooh-pooh the lab tests, which I am guessing they also have never had done. Blackstone tells you a lot of stuff, including bearing wear and other information, as well as the condition of the oil.
I would say these unfounded comments that synthetic is a waste of time and money do not reflect well on those who make those statements, with no real foundation or knowledge. Just personal opinion.
I do agree that if you do somewhat normal driving, and want to over-change regular oil every 3,000 miles, your car will last a very long time. But, it is also true one can go a lot longer if you use a good synthetic. That is, once warrenty is up, you can indeed extend the change cycle. I now have personal knowledge of this, and this tin hat stuff wears thin.
