Some product, same SKU, different copyright dates, same price. One says 10,000 miles, the newer one says 15,000 miles.
The the more modern left package has a more minimalist design on the back with fewer words and less technical information, just like many modern websites. On the front, the mileage has been inflated.
Open the image on your computer. PC? Right click in the window background. Select “Save As” from the drop down. Look under the image name at the bottom, save as type- select .jpg or .png from the pull down menu…
Look at the API qualifications. The enhanced mileage one is rated to the latest standard SQ. The formulation of the oil may be no different but has been tested to the new standard. Or perhaps it is slightly different, allowing it to meet the more rigorous standard.
Which is a problem for anyone who doesn’t have a vehicle made for the SQ specification. I know the newer cars often have higher oil capacity which equates to longer oil life. It must be technically correct for them to remove the SN PLUS, SN, SM, and SL compatibility on the back of the newer package, since it is not rated for 15,000 miles for those vehicles.
Note that all of these oils require changing after one year, so ‘25,000 miles’ is not that big of a deal. As for the change from 10,000 to 15,000, it’s a new spec, as noted above. I wouldn’t call it ‘inflation’, I’d call it ‘improvement’. They’re putting their money behind the claim, not a problem to me.
Maybe it always was but they were limited to what they could claim based on the specifications at the time. Maybe they added something to the oil that allows it to suspend more particulates and so it lasts longer. Or the long chain polymer formula resists shear longer. I can think of many different ways this could play out. The SQ supercedes the prior SN et al meaning it is better in certain ways. Therefore it may very well allow for extended use in the legacy applications as well.
I could even see the case where they changed nothing in the oil, but found through testing that it could handle a 15,000 mile/12 month OCI sufficiently well that they were willing to put their guarantee on it. What’s wrong with that?
Just asking for a friend but what kind of person would pay $70,000 for a piece of equipment and not change oil for 25,000 miles regardless of labels and advertising?
Mobil also knows it is all but impossible to definitively say that the sole cause of the engine failure was their oil…
Their Limited Warranty states: “If an engine failure occurs directly due to a defect in the lubricant, ExxonMobil will pay to repair the equipment damage.”
I think the “15,000 mile” pitch is more a sales tactic and not all that many folks will take them up on it and those that do are in many cases folks who would have run the “10,000 mile” oil that far anyway…
Notice in the top photos that the oil is Euro spec oil. The Euro manufacturers extended the change interval a while back to reduce pollution from spent motor oil. Also, I read test results from a government motor pool in California where they measured engine degradation in their fleet, which consisted of buses, large trucks, and even Chevy Cavaliers. In all cases they saw that they could extend the oil change interval substantially. Their reason for the test was to see if they could save money by reducing oil change frequency. That makes sense for a large motor pool. BTW, the Cavalier extended interval is 10,000 miles.
Pollution from spent oil? Oil is now captured and recycled. For a normal consumer going from three to one change a year might save $100. It’s simply a cost vs risk calculation.
