I have a 2005 Suzuki Forenza. The low beam headlights will not turn on. The bulbs are new and the fuses as well as the head light relay are good. Is there another connection to check beside the wires (which are clean and intact)
With the light switch on, do you have current at the low beam headlight socket?
There should also be a relay in the circuit someplace. Flip the switch, power flows through the fuse, energizes the relay, which then supplies power to the lights. If relay shot, no lights. Usually separate relay for high beams and low beams. What you need is the factory manual with the wiring diagram.
