Preparing to install replacement cylinders on the 2002 WRX. Received OEM replacement from dealership. Cannot move the piston( extended). Is there a lock on the cylinder or technique to move the piston to ease the installation vs. trying to install at set length?
try peeking at nasioc.com or ultimatesubaru.org if nothing comes up here.
You can have a helper hold the hatch up while you change it. Those rods stop and you just push the hatch higher. It’s easy with a small hatch and a bit more tricky with a heavy one. Get two helpers.
You’re supposed to install them at their extended length. It’s VERY difficult to compress them. Find a way to keep the hatch open (helper or some sort of prop) while you install the cylinders.
