I have a 2004 Subaru Outback and one of the bulbs on the dash (that illuminates the speedometer) is burned out. How do I go about replacing this?
You buy a Haynes repair manual for your car (they’re not terribly expensive), and you follow the instructions in the manual.
You will have to remove the instrument cluster. It’s not as bad as it sounds, as long as you have a repair manual to guide you.
Repair manual: $25.
Dealer repair bill: Three figures, minimum!
Fix it yourself and save your money.
