I have a 97 Outback with the 2.5, and 180k miles on it. It idles rough, and shows codes for misfire on cyls 1&2. When I bought it (used, last year) the check engine light was on, so I did a semi-tune up and replaced plugs and wires. When the plugs were out I checked compression and it was 160+ in all 4 (engine was supposedly rebuilt at 120k). A vacuum guage shows normal steady reading. Timing is set properly. So… I replaced the coil, feeling it was the last possibility. Nope. What do I look/test for next? Other than the shake at idle it starts/runs well, gets 24 mpg and accelerates fine. Was told possible head gaskets, but wouldn’t that lead to low compression?
Related topics
| Outback missfire | 6 | 811 | August 12, 2009 | |
| Misfires on the right side only (cyl 1,3,5) on a 2001 Outback LLBean | 44 | 24519 | July 12, 2012 | |
| 2005 Subaru Outback 2.5i Cylinder 4 Misfire help | 15 | 23148 | March 17, 2015 | |
| 2002 Subaru Outback mystery problem | 3 | 2434 | October 6, 2010 | |
| Miss-fire on #2 spark plug in a 96 subaru legacy | 10 | 3747 | January 27, 2011 |
