I had my 2002 Dodge Intrepid lowered about 5 years ago. Will this shorten the life of the struts or will they last as normaly as if I didn’t lower it.When I drive really slow I hear noises coming from the front fender wells
How much was it lowered? Have you hit bottom?
It was lowered about 3-4 inches, they replaced the regular springs for shorter ones. The wide tires scrape the inside of the fender well when i’m turning sharply going down hill, so if thats hitting bottom it only does it in that type of situation.
