I have a 1996 Nissan Maxima that has had starting problems for the past 4 years. When I turn the key, I hear nothing, for the first couple years I could turn off the air conditioning and jiggle the key a little and it would start. in the last several years I have had to turn all power accessories off and jiggle much harder. When it is hot outside, it has much more diffiuclty starting and usually I have to air out the car for a minute or two. After it has started the first time, it is easier to start thereafter, even when sitting in the sun.
You might want to change out the inhibitor relay switch Located in your Fuse Box #2
located underneath the hood. It should be the one right in front of you when you open up your hood. It will say…Inhib / clutch iter lock   …and thats is
you pull that out and replace it you should be good to go…
