Squealing noise in 1996 mitsubishi galant!
My car tends to make this squealing noise everytime I turn it on. Before it used to be a short while and then it would go away. lately it gets longer and longer before it turns off. It as also begun to occur when ever I drive after having stopped at a red light. I previously had this issue and my mechanic said it was my belts which he replaced. The noise came back and he tightened the belts. this worked out for a couple of months but it is back and worse. My mechanic now suggestes that he would have to take the engine apart to figure it out. I am hoping someone may have an Idea of what it could be aside from the belt? Or can it only be associated with the belt? help please!
You need a new mechanic. Anyone who says they’d have to take the engine apart to figure out a belt squeal problem can’t be trusted. This mechanic is trying to make you go away.
So, go away.
You know it’s the belts because the noise stopped for a while (a couple of months). You’ve described a classic case of slipping accessory drive belts.
Take the car to a different mechanic.
There may be a mechanical problem with one of the driven accessories (alternator, power steering pump, AC compressor, etc) which is causing the belts to slip. Because they’ve been slipping, and squealing, for a while, the belts are shot, no matter how old they are, and definitely need to be replaced.
Tightening won’t stop the noise. You need new belts, and you need a mechanic who will check the driven accessories, check the alignment of all pulleys, and install and tighten the new belts correctly.
There is nothing inside the engine that makes a squealing noise, even under the worst of circumstances. Suggesting that the engine needs to be taken apart to find the source of the noise is ridiculous.
Thanks so much. I will definitely go to a new mechanic and hopefully they can figure what is wrong.
Most likely cause is a belt tensioner or idler pulley needs replacing.
