2000 gmc sonoma 4.3L V6 (vin has the W). I recently replaced the serpentine belt and the tensioner. After replacement I have a knock and my new belt is chirping at me already. I pulled the belt off and ran truck for a couple seconds. The knock is gone with the belt off, so I know it’s not in the block. I replaced the tensioner again, because I had another and at least wanted to eliminate something else. So I know it is not the tensioner and not the block. Basically in the past week the truck has had 2 tensioners and 3 belts on it now. The only other thing I can think of is that my ac has not worked for some time. The clutch used to kick on then right back off repeatedly, now it doesnt even kick on. I did tap on the clutch to see if it was stuck. That is the only thing I have done prior to the knock (other than the already mentioned belt stuff) Any ideas?
Related topics
| Knocking Noise After Timing Belt Change | 12 | 35119 | August 7, 2020 | |
| Serp belt noise | 6 | 952 | December 1, 2016 | |
| 2006 Hyundai Sonata V6 Serpentine Belt | 11 | 8046 | November 8, 2014 | |
| Crummy deal in Vegas | 6 | 665 | June 9, 2008 | |
| Squeaking/chirping when starting and driving, goes away after a while, 97 GMC Suburban | 9 | 3674 | October 19, 2022 |
