5 awg wire resistance is 0.0003 ohm per foot. Doesn’t seem like much but w/100 amp flowing during cranking attempts the voltage drop is 0.6 volts for a 10 foot run or two wires. That subtracts from the voltage needed at the starter and could be enough to prevent cranking.
Also discount jumper-sets (from my observations), the sort offered at flea markets etc, new products, seem like they use less expensive wire material and may not meet the resistance spec’s for the wire gauge they are advertised to use. The electrical bond between the wire and the clamp can be suspect as well.
As mentioned above, what w/the price of car electronics these days, I wouldn’t recommend either giving a jump start, nor receiving one, except in an emergency situation. I just recharge the battery overnight using a battery charger.
