2003 Mazda Protoge starts and runs good, with exception of idle at red lights, etc. Idle gets very rough to near stalling. I changed plugs and air filter. Any suggestions?
Rough idle with a warm engine is generally the result of a vacuum leak.
Could be a vacuum hose split or disconnected, a failed intake manifold gasket, a leaking EGR valve.
There are other possible causes besids vacuum leaks, and other sources of vacuum leaks, but that is where I would start looking.
