I have 2002 Chevy trailblazer, my alternator went out so I replaced it myself. Now my check engine light is on and a/c wont kick on. What shall I do or check first?
There are error codes stored causing the check engine light. Have them read for free at a local auto parts store. Post the actual code here in the form P1234 and we will try and help. Also, how many volts do you see when the engine is running?
It may have nothing to do with the alternator replacement or it might.
You may have dislodged a vacuum line or wire when replacing the alternator. Also check for a pinched wired. The actual error code(s) can give you guidance of where to look if there is nothing obvious.
Reset the connections to the compressor and or clutch, one thought
Along with checking for any loose connections in the area you did the work check the fuses under the hood to see if any are blown out. If one of the battery connections wasn’t disconnected when you did the repair work the main lead to the alternator may have touched ground and shorted, thus blowing a fuse.
We removed the negative cable on the battery before doing any work at all, the battery was drained and it’s a screw in side post so couldn’t charge it up until we had it all back together. Then put it on slow charge for 8 hours, fuses are all good.
Well then you should check the engine codes and check for power to the AC system.
6 cyl engine? I’m guessing you unplugged the coolant temp sensor which is under the alternator. If the car sees an obviously incorrect or missing engine temp reading it will disable a/c operation in case it’s overheating.
Did you put the serpentine belt back on correctly?
Just an idea.
