Barkydog, and Criss,
let’s meet and try it… for real…
Criss, see your car talk inbox.
I have an another idea for what Criss (and maybe Barkydog) are missing.
Criss, in your note from March 11
But, the sides are not independent.
there is a correlation to consider, but in this case it doesn’t seem to matter.
Perhaps there’s some commutative property in effect.
In any case, my post on March 4’th attempts to explain in terms of picking cards,
then picking a side. This is more in line with how it appears you’d like to think of the problem.
I got 2/3 for red, etc.
If you see a R side up, the GG card is out of consideration.
true.
The R side that is up is also out of consideration because we know what it is.
The color of the bottom side, then, is actually the probability of drawing a RR card over drawing a RG card.
If this is wrong, I just do not see the fault in my un-logic.
I think what you’re missing is how to count the case when the G side of the RG card shows up.
It may be easier to consider this when drawing 2 cards: R/R and R/G
As I did on March 4’th.
You can work with 3, but it gets a little confusing since the cases you “throw out” will depend on the color
of the side you see.
With two cards, what would you do with the case when the G side shows up?
not count it?
you have to consider it somehow.
it is a possibility.
With 2 cards, the chances of picking the R/R card is 50:50,
and picking the R/G card is 50:50,
but if you “throw out” the cases when G shows up, you’re left with
two out of three times; when you see red, then the other side is red.
all the enumerations presented by Triedaq look correct to me.
