i have a 94 dodge van with a poping noise when i accelarate thru the throttle body i check the plugs /wires /compression /vaccum leaks replaced coil / still poping i was thinking along the lines of maybe bent push rod /colapse lifter bad valve spring what do you think what are your thoughts
Related topics
| Pop bottle-like noise | 2 | 525 | November 28, 2009 | |
| 1996 plymouth popping thru intake | 1 | 380 | February 15, 2010 | |
| 95 dodge ram van | 1 | 243 | September 15, 2008 | |
| Volvo 960 Popping Sound when accelerating | 0 | 437 | July 11, 2009 | |
| Escalating Hesitation-Then-Jerk-Forward Issue | 57 | 18370 | April 17, 2017 |
