I have a 2005 chevy tracker. It came from the factory with a 2.0 suzuki engine. It has failed emission 3 times for NOx.
6 months ago, had the top of motor rebuilt. Coolant is good, fan is running, car does not over heat.
1 time fail, changed the Cat Converter. I don’t remember the data for NOx
2 time fail, changed the EGR Valve. NOx 1000+
(when I picked the car up the check engine light was on for the 1st time, then the mechanic cleared the code that caused the light. He said it was because of the change of the EGR valve.)
Other than the obvious EGR system problem there could be an intake manifold leak which could cause too much oxygen to get into the combustion chamber. Then there could be a leak at the EGR valve or near the EGR valve.
Something is preventing the exhaust gases from entering the combustion chamber. The knock sensor could be malfunctioning and over advanced ignition timing may be contributing to the problem.
the code was for the MAF. i disconnected it while running and the idle got a little better and the car did not stall. i ordered another one and it will be here on the 12th. any thoughts?
