I had a water pump go bad while driving down the freeway. I didn’t want to pull over on the freeway so kept driving till I got to the next exit. I was watching the temperature gauge. I found out afterwards the gauge is not accurate. So, it was overheating when the gauge said it was running somewhat warm but far from overheating. I had it towed home. I changed the water pump and test drove it. It took at least 5 seconds for it to start. But once running it ran nice. On a short test run I could hear it was boiling over by time I got back home. It would not start back up to get it into the shed after it cooled down. I charged the battery and will be trying to start it tomorrow.
Yes, I should have pulled over on the freeway, stupid move.
There does not look to be any water in the oil. I am going to check the spark plugs to see any have signs of water. How can I know for sure if it’s the head gasket or something else?
I’ve seen a few youtubes on products that might work like bars leak and Scotty Kilmer with Steel Seal which is over $100 but comes with a money back guarantee.
So, How can I know for sure if it’s the head gasket or something else?
