Dear Bros:
You recently had a question about tire pressure and why it
doesn’t seem to change with the tire on or off the car. I too have
pondered this mystery and concluded the explanation lies in the
wheel and tire’s internal surface area. But how could I calculate
that area?
Since a tire is in the shape of a torus (that’s the doughnut, not
the Ford) I sought the opinion of a local expert but abandoned my
research when I noted his hand moving slowly from his handcuffs
to his Beretta (that’s the pistol, not the Chevy).
Retreating to my garage, I spied the wife’s 2007 Toyota
Camry fitted with 215x60x16 tires and realized I could approximate
the needed data. Knowing there are 25.4 millimeters per inch, and
rounding off any deciamls, I quickly calculated a tire diameter of
26 inches and a width of 8 inches.
Computing the area of the tire’s 26 inch diameter and
deducting the area of the 16 inch wheel, I arrived at 330 square
inches contained within each of the tire’s sidewalls. Then,
multiplying the 26 inch diameter by the 8 inch width and by pi
yielded an additional 653 square inches of area under the tire’s
tread. Finally, deducting an inch of width on each side for the
wheel rim and tire bead’s thicknesses, I multiplied 6 inches times
the wheel’s 16 inch diameter, times pi for an additional 301 square
inches of area on the inside surface of the wheel.
All of this adds up to a total internal surface area of
1,614 square inches. Multiply this by the manufacturer’s
recommended 30 pounds per square inch tire pressure and we see the
wheel/tire combination contains a total pressure of 48,420 pounds.
Wow!! No wonder blowouts can be so loud!
Given a weight of 4000 lbs for the wife’s Camry, we see
that jacking up one corner would affect that 48,420 lbs pressure by
about 1,000 lbs, or around 2% of the total pressure. This would
change the measured pressure by about 0.7 psi which is barely
noticeable on the typical mechanical tire gage. Mystery solved.
I hope this explanation satisfies Amy, her dad and
Wolfgang.
Sincerely,
Todd Smith
Suwanee Ga
