Hello everyone,
Today when I was driving home from work, I glanced at my temp gauge and saw it was slightly past the halfway point. Maybe 65% of the way between all the way cold and all the way hot. Definitely not overheating but hotter than usual. (I am taking car to mechanic this weekend for diagnostic.) I kept a close eye on it and drove the rest of the way home for 20 minutes but it didn’t go up anymore. However the check engine light came on just as I was arriving home and I borrowed neighbors obd scanner and the code was P1285. Which is a cylinder temperature overheat condition. Why did it throw this code when my car didn’t overheat? 65% of the way up on the gauge is definitely not overheating. Should I be worried I caused some severe engine damage by driving home with the gauge slightly higher than normal?
My question is; will the computer throw an overheat code if it detects the gauge moves even slightly past normal temperaure, even if the car didn’t actually overheat?
Edit: It appears my coolant levels were normal and there were no visible leaks anywhere so that can be ruled out
