Hello and thanks … 2005 Rio with 130 000 - 5 speed … burning a bit of oil but otherwise runs ok.
Car runs and drives without problems, but once in a while, several times a week, it will miss fire on take off. Starting out in first, it will hesitate, lose power; I feather the gas, the RPM’s come back and car runs normal . However, If I go WOT , the car will set a soft 304, it will continue to run rough, until I restart the car, the MIL is off and car is ok.
I have done a tune up, plugs wires, coil, and replaced wires connecting to the coil. Any thought would be helpful thank you
Geo
