My Honda maintains normal temperature when on level highway. Climbing to 3000 feet (from about sea level) overheats to the red. It has a new radiator. After the first time I removed the thermostat. It does not lose liquid. After reaching 3000 feet and on level run it returns to normal. There are no leaks around the water pump. What should I try next?
This is a classic symptom for a radiator cap that is not holding the specified pressure. Try a new cap. If one came with your new radiator, it could be defective or the wrong pressure.
