Overheated Engine
My radiator gave way on the highway, and by the time I noticed it the temp had maxed out the gauge and all the coolent was gone. So, I only have 90k on my '94 Camry and I’m debating whether to tackle repairs and perhaps a rebuild if necessary. What’s the likelihood that there’s damage to the rings, bore, crank, valves, etc due to the overheat? How much repair am I potentially looking at and what can I check without a tear-down? I’d like to get it running again since I just invested in new struts, brake calipers and MS and tires (not to mention that it has been pretty-much worry-free until now), but I want to know whether it’s even worth my while. Thanks for any advise someone wiser and more experienced can offer.
The first thing that usually happens to an overheated engine is the head warps slightly and the head gasket fails. You may as well put in a new radiator, fill up with coolant, and hit the road. If your coolant level stays full, you’ve dodged the bullet and can just keep driving.
If the coolant starts to disappear, or if the engine overheats again, then you probably have a failed head gasket due to a warped head, in which case you could choose to have the head removed and machined, or put a rebuilt head on it.
But, I see no point in tearing down the engine now. I’d do the minimum to get it back on the road, and hope for the best.
Get the cooling system repaired and see if it will start and run…If everything seems okay, re-torque the head bolts to specification as this can prevent the head gasket from failing…
I’d run both a dry and wet compression test and go from there. If those tests, especially the wet test, reveal a ring problem then you have a tough decision to make.
I second what Jesmed said. Fill it up with coolant, start it, and assess how much damage was done. If the engine got hot enough to warp the head or blow the head gasket, you might be better off just putting a salvage yard engine in it if you plan on keeping it. If it got that hot, it will probably never be right again without a total rebuild. But I’d see how it runs and if it’s losing any coolant or using any oil before planning for the worst.
You did not say how long you drove the car without the coolant and with the engine temp pegged. If it was for 2 minutes or 20 minutes it makes a difference.
Not likely that anything worse than a warped head with the engine and this is a $1000 repair and worth doing if needed. As already mentioned have the radiator, hoses, and water pump replaced and the shop can do a couple tests for both pressure and to see if coolant is getting past the head gasket and into the engine.
The coolant leaking into the engine is what can cause severe damage to the engine and needs to be monitored. Even if the car is repaired and passes all the testing with flying colors I would monitor the coolant level weekly and if you see it going down at some point in the future have the engine retested for a head gasket problem.
What does your oil look like? Nice and clean? Black? Light brown and frothy like a milkshake? Before you tear the engine apart, have someone run a few basic tests, like ok4450 suggests, even before you invest in a new radiator. Rocketman
