Only one spark plug is getting carbon fouled?
There is no low compression code. There is no sensor to measure that. You might see a misfire code and it could be intermittent. Leave that plug in a while longer and you are highly likely to see a misfire code set.
You can’t rely on the cars computer to tell you everything that is wrong. It isn’t that smart. Sometimes you have to go back to the basics. Vacuum tests and compression tests.
