Ok to monitor very small oil pan seal leak?
I recently noticed drops of something on the floor of our garage under the Kia so I took it into Firestone to have a leak-check done. They determined that the seal on the “upper” oil pan has a very small leak, with it accumulating down below on the frame and occasionally dripping from there. Unfortunately, it’s a $2600 repair; given the position of the upper oil pan it requires dropping the transmission to replace the seal.
As the car has 104,000 miles, I’m on the fence about whether to make the repair or sell and buy a new car. In the meantime though, my question here is whether there is a specific risk to the car if I just monitor the oil level and if necessary top it off. The leak is so small that in the past 3 weeks the oil level on the dip stick still shows Full.
I’ve seen other online thread where people have talked about doing that and it not being an issue to have lost a quart between oil changes. On the other hand, anything from Kia or other similar sources says absolutely do not delay in getting an oil pan seal leak fixed.
Thoughts?
All you need to do is monitor the oil level for a while to get a sense on how fast the oil leaks out.
Once you know this, you know when to add oil before it gets below the low mark on the dip stick.
And if you make sure that doesn’t happen you can keep driving the car.
Everything teater says is true but I would not recommend going to Firestone, Pep Boys or any national oil change, or tire chain. Make an appointment with a local real mechanics shop for his opinion and estimate.shop that is very busy. That usually means that people have usually found them trustworthy and competent.
I once stopped at a local Firestone Store to drop off a tire to be repaired and when I walked in, the color all drained out of the managers face. It turns out that I was a dead ringer for the inspector from our State Attorney Generals office. Hardly confidence inspiring.
Definitely just monitor the situation over time. Keep several bottles of the proper oil on hand to top off. I’d also suggest putting a large piece of cardboard or flattened box in the drip area. This will both help contain the “mess”, and help you monitoring the dripping.
Just about every time with an oil leak, it’s far easier/cheaper to just monitor your oil level and keep it topped off. Oil leaks are rarely cheap to fix.
The oil filter on our Olds Silhouette was above the front axle and it got wet every time the shop changed the oil filter. We cut up a big box and put a large side under where the engine sat when parked in the garage.
You don’t need to have it evaluated by a mechanic just yet. As mentioned above, check your oil level and see how long it takes to leak a quart of oil. Whenever you are a quart low, add another. Keep a list of how long it takes to lose a quart. You should check your oil every one or two weeks at first I case you lose a lot in a short time.
NEaton certainly made a strange choice for thier Avatar .
It seems to be rather unique
I would also just keep a close eye on the oil loss at this point
Might be one that he has had for a very long time like for gaming or something, and now a business?? Neat looking, def grabs your attention…
Mr Google shows this…
Thanks for all the feedback.
BTW, regarding my avatar it’s an art piece.
The artist post:
https://yuccaflatsnm.blogspot.com/2014/03/calaca-giveaway.html
My portrait:
https://yuccaflatsnm.blogspot.com/2014/09/september-calaca-winner-nathan-eaton-jr_2.html
I don’t think Art is the correct word.
Art is in the eye of the beholder.
Different strokes. I kind of like the Dia de los muertos version of Max Headroom he created or is using.
Me, I like Van Gogh, do not like Picasso
I like most shades of green cars, others don’t.
I think M.C. Escher is my fave. I don’t think he did any works with vehicles in them, so I’ll post this shot of someone who had his Self-Portrait in Spherical Mirror put onto a car’s hood:
I’m partial to Dale Chihuly. Here’s an example of the exhibit at Chihuly Gardens and Glass in Seattle.
Edit: that’s all hand blown and formed glass.
Or airbrush art of the ‘80s, today would be done on a computer and printed on a wrap.
Oh wow!! You mean people are allowed to have different taste and opinions in art???
Who’d a thunk it???..
In recent years there have been two exhibits of Chihuly blown glass at the Missouri Botanical Garden here in St. Louis. Generous private and corporate donors purchased some pieces to be permanent installations in the garden. They are stunning pieces of crafted art glass.
@NEatonJr
I looked through your git repositories. Very cool projects.
I’m curious what triggered your interest in those activities?
– For example, developing a magnetometer to read your water meter or gas meter.
– Or a reader with an interface that reads Smart Meters between various utility companies located in Texas.
– Or an open-source dataset of breweries, cideries, brewpubs, and bottleshops.
And many others.
Atlanta has one too, and it has been there for a while. My son in law visited it as a teenager, about 15 years ago. The Seattle exhibit is the home museum.
Joe,
Thanks. I have a wide variety of interests… home computing, home automation, home brewing, sailing, photography, astronomy and more. In general, if there isn’t already a solution for something I have an interest in, I don’t mind rolling up my sleeves and working up something myself. That said, although I am a retired software architect, my hardcore programming days were decades ago so I’m often adapting work someone else has done. Open source is my friend! As are AI chatbots with programming capabilities. :slight_smile:
It’s interesting how far afield this thread has gone from my original question. I would not have expected to go down this art rabbit hole - but pleasantly surprised. And I’m always happen to talk about my toys and projects. :smiley:
With that in mind, I might as well share my other passion, my blog:
Wind-n-Sky
