@meanjoe75fan
Not to worry. There is no other way to disagree then state what You think. Everyone has a right to heir own opinion.
There are motors in the Toyota stable that have not been certified to use the thinner oils either, even though they might benefit from them. We are not privy to the slight and relativly minor changes that must be made to do it either. If you think cars are treated differently from one country to another, that would be a good question to ask the company. We know that for sure in towing and we do find both political and actual construction differences.
You cannot discount that thinner oils yield better mileage but you can’t discount either that cars gradually moved to thinner oils over the years using mineral oils too along with longer oil change intervals. And, they performed better too and last langer because they also had tighter tolerances which are necessary for this performance. Using multigrades ilicitted the same negative feedback yet, I have seen no one disagree that much of the wear occurs during start up and all thinner synthetics had disticnt advantages there in both cold weather performance and longevity while still not breaking down at temps.
I just continue to be amazed why some of us keep referring to the owners manual as the proper way to maintain a car for the longest period of time, until, it contradicts what ever long standing opinion we have. Then, these same engineers don’t know what the heck they are talking about. Thin oils and longer change intervals is one those those things that’s tough to accept. But it has been going on since the internal combustion engine has been in existence. Has it been politically motivated ? Sure, but so hasn’t the cat and others which ultimately helped motors perform better and last longer, including their exhaust and other systems.
